S10 WiFi Music Streamer
In Stock & Ready To Ship:
Choose the plug type first
Entry-level WiFi Music Streamer
Easily Stream Your Audio Wireless
The S10 is a great WiFi music streamer for new wireless audio players to get started on budget.
The S10 wireless audio receiver allows you to stream audio to your home audio system wirelessly via WiFi, AirPlay, Bluetooth 5.0 and Spotify Connect.
You can also add other Arylic wireless streaming devices to build a multiroom system, manage and control all your wireless audio devices in one app (4STREAM)!
Multiroom Audio System
Mix and match any combination of Arylic streaming devices to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones...
All are controlled via our 4stream App.
Kitchen
Wireless ceiling speaker for kitchen.
Bedroom
Wireless music streamer for desktop system.
Balcony
wireless ceiling speaker or on wall amplifier for your balcony or gardan.
Bathroom
Wireless music streamer for bathroom.
Living room
Tune Like An Expert
Fine tune your listening experience with our exclusive ACPWorkbench tuning tool.
Find the perfect sound for each channel with EQ, Bass Enhancement, Advanced DSP effects, Gain, Pregain and more.
5V/1A Micro USB Input
Analog
Line In x 1 / 1 Vrms(3.5mm mini jack)
Digital
Micro USB Input x 1
Line Out x 1 / 1 Vrms(3.5mm mini jack)
Decoding
Up to 24bit/192kHz
Output
44.1khz/16bits, CD quality
20Hz-20kHz
0.03%
91dB
0.2kg(0.44lb)
What Is The DAC Inside S10?
Can I Connect External DAC With The USB Port?
Can S10 work with other Arylic products for multiroom?
Is it possible to use the Bluetooth or USB only without the App?
Is S10 support DLNA & NAS?
It has received 291 reviews.
