Expansion Boards
Sale price$25.00
Model: DAC Board
Up2Stream DAC Board
Upgrade the sound quality of your Up2Stream board with the famous ESS 9023 Sabre chip found in the Up2Stream DAC Board.
Compatible Products: Up2Stream Mini, Up2Stream Pro
Up2Stream Button Board
This Button board is an external board that contains multiple control buttons including play/pause, volume up, volume down, previous song, next song, standby and switch mode, plus an on board IR receiver, connector for IR Extension Board and 4 mode indicator LED including WiFi, BT, AUX and USB.
It is perfect to use as the control panel for your DIY device.
Compatible Products: Up2Stream Mini, Up2Stream Pro, Up2Stream Amp, Up2Stream Amp Mono, Up2Stream Amp 2.1
*Up2stream Plate Amp, Up2stream Plate Amp 2.1, Up2stream HD DAC need to wiring yourself.
Up2Stream S/PDIF In Board
Lacking a digital input for your DIY board but want an easy solution?
The S/PDIF input board lets you easily add S/PDIF input to your device. It contains both an Optical input and Coaxial input jack. With this board, you can connect any device with S/PDIF output as a digital audio input source.
*Up2stream Plate Amp need to wiring yourself.
Up2Stream S/PDIF Out Board
This SPDIF output board can add digital output to your device, which contains an optical output and coaxial output jack. With this board, you can output digital audio data to other devices like a DAC or digital amplifier.
Up2Stream IR Extension Board
Does the onboard IR receiver not fit your DIY case? Do you need to position it somewhere else?
This IR extension board lets you connect an external IR receiver and position it to fit your DIY needs.
*Requires Up2Stream Button Board or Up2stream Pro, Up2stream Amp, Stereo, Up2stream Amp Mono, Up2stream Plate Amp, Up2stream Plate Amp 2.1, Up2stream HD DAC need to wiring yourself.
*Up2stream Mini requires Up2stream Button board.
Up2Stream Volume Knob Board
Need a volume knob on your DIY project? Then this is perfect for you! U
se this Volume Knob Board to add a volume knob to your device. It is a combined rotary encoder and momentary switch you can use it to turn volume up or down, and for Up2stream Mini, switch input mode with a press.
Compatible Products: Up2Stream Mini, Up2Stream Pro, Up2Stream Amp stereo, Up2Stream Amp Mono.
Model
Up2stream DAC Board
Up2stream Button Board
Up2stream SPDIF In Board
Size
40x38mm
68x64mm
52x24mm
Sample Rate
up to 24bit/192KHz
up to 16bit/176.4MHz
Audio Output
44.1khz/16bits, CD quality
Dynamic Range
112dB
Interchannel Isolation
100dB
THD+N
0dB FS 0.002%
Power supply
3.3V ± 5%, 23mA 5.0V ± 5%, 31 mA
Model
Up2stream SPDIF Out Board
Up2stream Volume Knob Board
Up2stream IR Extension Board
Size
52x24mm
22x17mm
18x10mm
Sample Rate
Sample Rate is same as the connected board
Audio Output
Based on 58 reviews
90%
(52)
7%
(4)
2%
(1)
2%
(1)
G
Gage W.
DAC Expansion board really made a difference
With the DAC expansion board the sound is richer and fuller with less of the harsh chopped frequencies coming through! I 3D printed a case for it and the mini to go in too. https://www.printables.com/model/529138-enclosure-for-arylic-up2stream-mini-dac
V
Vacuumsource LLC
SPDIF Out Board
These work great, Very easy to install just plug in using the matched cable (included) with the correct DIY board. I like this option when using an external Amplifier that takes OPT/COAX inputs my flac files never sounded so good!
Michael Howze
Multiroom system
I bought several units to build several rack mount whole house audio system that was easy to operate, the flexibility of the design and parts used worked great, only thing I personally wished that would work is the Napster streaming service, as it is one I use across many devices, but when I go to sign in it does not connect, even though I use correct credentials.
F
Frank Bastrup Jørgensen
Speedy process
Easy to order and delivery os quick.
C
Charles Poxon
SPDIF out board
Originally had SPDIF in board and purchased a SPDIF out board - it connected very easily BUT it did not want to output. Contacted support and to be honest it was no help at all. Trawled through your support pages and eventually made some progress with settings and firmware, but still have not got SPDIF output - have given up for now, because I use the Up2stream 2.1 amp board most of the time and love using it. So I am disappointed with the poor layout of support and lack of documentation / instructions that may have helped get the spdif out working - after all it is not rocket science!
Still like Arylic products but will be cautious as to what I purchase in the future - buy boards with all the features already installed
Many thanks Charles
D
Dobritan Radu
Great stuff
The products are great , I like them verry much . Easy set-up , easy app, and a lot of options for combining them. I usually use them for home applications , but they are great and cost affordable for business aplications also. Using the dedicated software , you can make the perfect sound sistem for your needs at a cost of bigger brands , and in terms of “real sound” there is no difference. If you choose the right speakers , with these amps you can get that great sound that on premium brand you’ll have to pay 10x the price. Fast and free shipping , great products for the products , and the most important , they all work together. Compared to other premium brands , and also cheaper products , they are fast responding , easy to manange and very diversificated options for a lot of applications
