H400 4-Zone Multiroom Streaming Preamplifier
Sale price$999.00
🍻Oktoberfest Sale
*Price calculate at checkout
  • Stream To 4 Zones - Independently, Or in Sync: Add network streaming, AirPlay, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers. Stream and control 4 different audio outputs at once, control all music wirelessly via our 4STREAM App.
  • Multiroom Audio System: Mix and match any combination of Arylic Streamers to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones... All controlled via our 4STREAM App.
  • Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The H400 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
  • Stream Any Kind of Audio On One Device: In addition to Direct Streaming from Online Streaming Services, AirPlay, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
  • Plug and Play: Power up the device and connect to your WiFi router with the Lan cable and it is ready to use.
✔Fast & Free Shipping
4 zone streamer
The M400 is a networked 4-zone streaming preamplifier that allows you to directly stream up to 4 audio devices at the same time, per M400 unit.
The M400 supports the most popular smart home systems, Fibaro and Elan, and will be integrated with more smart home brands in the future.
Home theater
Stream To 4 Zones - Independently, Or In Sync
Add Direct Streaming, AirPlay 2, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers.
Stream and control 4 different audio outputs at once, controlled wirelessly via our 4STREAM App.
4 zone streamer with optical input
In addition to direct streaming from online streaming services, AirPlay 2, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
Home stereo system
4 zone audio receiver
The H400 comes with optional mounting brackets for installation in standard 19" racks (1U height).
smart home system
H400 comes ready to integrate with Fibaro and ELAN Smart Home installations, with an RS-232 port to connect to your smart home control unit.
Integrate and control your H400 with your smart home programs.
M400, User Manual, Ethernet Cable, 12V 2A DC Power Adapter, Rack Mount Brackets x2.
Wireless 4 zone preamplifier
Newest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Ethernet Single 10/100M RJ45 In
Ethernet RJ46 Out
(Output to other device to share the network)
Streaming Protocols
AirPlay 2, DLNA, UPnP, Spotify connect, Qplay
Music Format
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Audio Format
Decoding up to 192khz/24bits
Based on 2 reviews
100%
(2)
Matthew
So powerful! Arylic H400
Just received my Arylic H400 and successfully tested it today. I’m using it together with a Raspberry Pi and HomePod mini to build a background music system. The H400 works perfectly for synchronized multi-zone playback, and also allows individual zones to play different music and adjust volume independently. Very powerful and promising — can’t wait to build more on this setup!
K
Kurt Simon
Awesome
It was a difficult find. I’m using two RUSSOUND amplifiers to feed in ceiling speakers in my large home. The M400 is the perfect solution to what I was looking for. I am able to stream to 4 zones through the built in Ethernet and everything works perfectly. Use Pandora and you can stream to multiple zones with one single account. The 4STREAM app is awesome as well. Very happy with this purchase. Expensive, but it pays for itself with how easy it is to use
You may also like
