A30+ 30W x 2 WiFi Mini Stereo Amplifier
Sale price$119.00
A30+ WiFi mini stereo amplifier perfectly suited for your passive desktop stereo system and smaller space. The compact stereo amplifier and easy to use design makes it easy for everyone to get started quickly.
Play online music service, online radio, local music files to your passive speakers by WiFi, AirPlay, Spotify Connect, anytime in every rooms.
🍻Oktoberfest Sale
*Price calculate at checkout
✔Fast & Free Shipping
stereo amplifier for desktop system
desktop amplifier
Small But Complete In Every Detail
A30+ mini stereo amplifier packs 30 watts per channel which is perfect to your desktop stereo system.
Enjoy the full functionality with wireless streaming: WiFi, AirPlay, Spotify Connect, Qplay, DLNA, UPnP, Bluetooth 5.0 and full features of our 4STREAM App: Online music, Online Radio, EQ Settings, alarm clock and more.
So does includes the ACPWokbench tuning tool features. The compact stereo amplifier and sliver surface makes your desktop looks more clear and premium.
Amplifier For Desktop
Best For Your First WiFi Stereo Amplifier
Our wireless streaming system is designed to be very simple, even for people who are not familiar with the electronics can quickly get started. There is clear step by step instructions in the app.
After the first setup of A30+ small stereo amplifier, you can stream directly from iPhone, iPad or Mac by Airplay or stream directly from Spotify both without app. The whole family can easily get started.
A30+ is a WiFi and Bluetooth amplifier for wired speakers.
Play High Quality Audio Without The Hassle
Streaming by WiFi has stronger range signal and high quality audio transmission.
With A30+ mini speaker amp, you can stream anytime, anywhere with far distance from the device. Upgrade your listening experience far from Bluetooth streaming before.
multiroom audio system
Hook Up Whole House Audio
A30+ mini audio amplifier can play a different song in different rooms, or the same track in every room, or play some rocky music for whole house party!
Bring Hi-end music to every rooms and controlled by one single device.
Music service
Versatile Playing
Play from Amazon Music, Spotify, TIDAL, Qobuz, iHeartRadio, TuneIn, Napster, phone storage, NAS, USB stick,line in source, bluetooth source and more.
Stream any audio you want all in one A30+ small audio amplifier.
mini stereo amp
Personalize Your Sounds
A30+ mini stereo amplifier supports ACPWorkbench tuning tool which allows you do specific EQ adjustment, L/R balance, dynamic range and more.
Set your favorite tune with different type of music.
A30+ WiFi Audio Amplifier, User Manual, Remote, 18V 4A DC Power Adapter, External Antennas (Bluetooth & WiFi), 2-1 RCA Cable, Screw Driver, 4 Pin Phoenix Connector (for speakers).
best mini stereo amplifier
Newest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Power Input
12V-18V/DC in
Audio Input
Analog:
AUX (1Vrms)
Digital:
Micro USB Input
Audio Output
Analog:
Not sure which one to choose? We selected our most popular Wifi and Bluetooth amp. Compare them and choose the best version for your needs.
WiFi, AirPlay amplifier, Spotify Connect, Bluetooth 5.0
Max Power Output
30W x 2
50W x 2
Analog Input
Line In
RCA In
Analog Output
Digital Input
Micro USB In
Optical In
Micro USB In
Based on 66 reviews
82%
(54)
18%
(12)
D
David Hack
Acrylic A30+ What’s Not To Love?!
I have used my new Acrylic A30+ to update a vintage 60’s HiFi stereo cabinet, and I couldn’t be happier with my decision.
I looked at, and tried, many other bluetooth amps, but was sold on the A30+ because it also had the WIfI use as well (which is almost impossible to find on other manufactured units - most only have the bluetooth ability. With the A30+ hooked up, I am able to listen to all my iPhone stored audio music, and internet radio, using the WiFi feature … which sounds much better than bluetooth in my opinion.
Using the remote control for the A30+ is my favorite feature. Also using the “4Stream” app on my iPhone works very good too. The “4Stream” app also works very well on my iPhone. Getting used to the ‘4Stream” app takes some time, but once you are familiar with the app, it fairly easy to set-up with the A30+. I also like the fact that with the A30+ “Remote”, I don’t even have to use my iPhone when selecting or playing my (6) favorite stored WiFi streaming radio stations on the “Remote” (SmoothJazz.com being my favorite).
Using an external portable CD payer is another great feature of the A30+. Simply use the 3.5mm “Audio Input Jack”, and you can run various accessories on the A30+.
I have also been very pleased with the Acrylic Customer Service. They were very accessible and always responded to my inquires.
Overall, I love the A30+ Unit, the design is small, it’s features are many, and the sound quality is great. I love it so much I now have three of the A30+ units, and one is just an un-used back-up should anything happen to one of them … as I can’t imagine being without the Acrylic A30+ !
David
Rochester, NY USA
a
ayoub badaoui
best amlpifier that ever existed, way better than expected!!!
This works great with my 4 ceiling speakers. very easy setup and enough power for rich audio. i contacted them before making the order and an agent was kind enough to explain everything related to this device, I never thought that a small machine can do all that this product does. it was also delivered very fast. very pleased with my purchase and i will buy more amplifiers for each room.
A
Adam
Works well!
Works really well for its intended use. Uses mostly Spotify and FLAC playback with and without multiroom and have no complaints. Phone app (4STREAM) is simple but works and easy to use. Firmware version is quite old (20220427) so I get a feeling that the product might not be updated anymore.
D
DOBRA ISTVAN
Mike Blomquist
Bought 4 and all worked great
No problems at all. The units arrived on time. All 5 speakers zones are working great.
G
Glenn Davis
Fantastic little amps
I have two of the A30 amps, one I use for streaming music around the house and the other is outside streaming on the Patio (don't tell Arylic but I actually removed the internals and put them in an enclosure for the outside). Sound is rich and compliment the speakers well, no issues with streaming via WiFi using Airplay and the app is useful too for listening to internet radio. Impressive for such a small unit. I will probably buy another for my office as well.
