B50 SE Bluetooth Stereo Amplifier
Sale price$89.00
🍻Oktoberfest Sale
*Price calculate at checkout
  • 50W x 2 Powerful Bluetooth Stereo Amplifier for Home
  • TPA3116D2 Amplifier Chip with High Efficiency and Low Distortion.
  • Bluetooth 5.0, Turn Your Old Speakers into Bluetooth.
  • 15M Long Distance Transmittion and Low lantency.
  • Free iOS & Android Go CONTROL APP with EQ.
✔Fast & Free Shipping
Enjoy Cinema Experience At Home
B50 SE is a Bluetooth stereo amplifier can power your passive speakers, active subwoofers and integrate your existing stereo system with it's rich interfaces. Easy to play with Bluetooth 5.0, and enjoy cinema like sound experience at your home.
B50 SE is a perfert Bluetooth stereo amplifier and bluetooth amplifier for wired speakers to fit any home usage. It can drive 30W x 2(8 ohms), 50W x 2(4 ohms) speakers for best sound performance.
The TPA3116D2 is an amplifier chip employs advanced PWM modulation and feedback control technology to accurately control the amplification process of the audio signal, ensuring reproduction clear, rich, balanced sound with low distortion.
Add Bluetooth Features to Your Speakers.
Make your speakers into Bluetooth-enabled, play any music you like wirelessly from phone, tablet, Laptop/PC and other audio gear.
Smoothly Sound Enjoyments
B50 SE Bluetooth amp delivers nearly imperceptible latency and stable Bluetooth transmission >10 meters in distance.
No matter you are watching movie, listening to music, gaming or wine time, you can have a smoothtly sound enjoyments without stuttering and interrupts with a good mood.
Movie
Music
Gaming
Wine Time
Compatible to Your All Audio Gears
GO CONTROL APP
Personalized EQ
Your can use the default EQ settings or custom your EQ settings with more bass, treble or vocals In Go Control App.
Enhance your listening experience with different music!
Simple To Operate
Easy to pair and manage All Arylic Bluetooth devices in one App. Remotely audio source change, EQ, L/R balance, device info, and more helpful features.
Custom Theme
GO CONTROL APP support to switch the theme between dark mode and light mode. What's more, you can change the theme color based on your flavor!
Tune Your Own Sound
Functionality Remote Control
Newest Firmware Version
0051-933309b3
Bluetooth Standard
5.0, 10m
Bluetooth Codec
AAC, SBC
Power Output
24V 4Ω 50W x 2
24V 8Ω 30W x 2
Speaker Impedance
4 - 8Ω
Bluetooth 5.0
Max Power Output
50W x 2
50W x 2
50W x 2
Analog Input
Phono in
Analog Output
Sub out
Sub out
Sub out
Digital Input
USB Type - C
USB Type - C
Micro USB in
Based on 20 reviews
80%
(16)
20%
(4)
P
Prakash Palaniswamy
Little wonder Box
I down selected B50SE due to its multiple input features in an affordable package skipping the HDMI, which I wasn't looking forward to. I was going through various reviews and was in a dilemma to own one or not. Finally I bit the bullet. I paired it with Polk RTi A1 bookshelf's. I was pleasantly surprised with the quality of output what it gave with my 320kbps mp3 files. I immediately fell in love with the "Deep Bass" feature and never expected smooth deep thumps from by A1 pair. Its a wonderful package and going to spend more time with this little wonder box.
j
jari lehtinen
erinomainen
älä jätä kokeilematta.uskomaton soundi. jaksaa soittaa or 310 lattiakaiuttimia vaivatta uskomattomalla bassolla ja kirkkaudella.täältä tulen jatkossakin tilaamaan suuret kiitokset.
Manuel De La Fuente Baños
Small big amplifier
The B50SE amplifier model, apparently the little brother of the B50, is compact in size or called desktop. With all the connection options it has; analog and digital, plus an efficient Watt power, it becomes a resolutive equipment, with HIFI sound capacity, with a simple, clean and functional design.
At the sound level, it manages to create an open, defined, and distortion-free field. Good dynamics and sound pressure. In addition, you have to take into account the options offered by the applications or the Arylic app to equalize, but personally I don't like it and I keep everything in Flat. For a small room or in a nearby field, the B50SE is very decisive. I recommend speakers with a max of 65w, not higher. Especially from the shelf with 8 ohms or 4 ohms will move them without problems. The synergy with this type of speaker is very good, it squeezes all the juice, as always if the speaker is of quality you don't need anything else.The connections of the speakers in the amplifier allow banana connectors, in loose cable, and in Y, everything helps to have a good cable connected.
This time the B50SE is connected via the Dac to a Mac, and the 48k output offers good sound quality. But in terms of the connection it has deficiencies, it is difficult to be recognized and it is connected with a high quality data cable, it still takes time and sometimes it does not appear and that's when it's time to be patient. You must improve your recognition on the PC by DAC. By RCA or Coaxial if no type of incident, loud and clear with a good cable.
In summary, the B50SE is an amplifier with an elegant design, good finish, with multiple connections, high efficiency despite its small size, with a very reasonable price for everything it offers and how it offers it. It is efficient and ultimately it will be to your liking for your desk or to set up a HIFI equipment is a small room.
A
Anand Kumar
B50sE
Ultimate book self speaker companion.....
S
Steve Y
Acrylic received
B50SE was shipped quickly, easy to set up and works just as I had hoped. Would certainly recommend to others. I plan to buy a 2nd one for another speaker set in another room.
D
David Tomsett
Great little amp
I got this as a gift and it’s a step up in features from my old Topping VX1. It’s easy to use and the sound quality is just as good as the Topping, it’s clean, clear and drives my Wharfedale desktop speakers with ease. Unless your speakers are very low impedance then this little gem would drive most bookshelves even up to £1k.
