H50 Wireless Stereo Amplifier
Sale price$249.00
- Airplay 2 Amplifier which works with Alexa, supports Spotify Connect and Tidal Connect
- Equipped with ESS9023p Sabre DAC and Qualcomm QCC3040 Bluetooth chip, supports WiFi 2.4/5G, and Bluetooth 5.2 aptX HD
- 50W*2 stereo channels with load switching for 4ohms and 8 ohms passive speakers;
🍻Oktoberfest Sale
*Price calculate at checkout
Power: 24V
✔Fast & Free Shipping
Stereo Amp
Amplifier for Home theater
Upgrade Your Home Theater
Play music directly from your Apple devices, and stream music to multiple AirPlay 2 devices at the same time.
AirPlay 2 Amp
Smart Your Life With Alexa
Works with Alexa Amp
Spotify Amp
Powerful Amp
Bluetooth aptX HD Amplifier
Brilliant Sound Performance
Amplifier for Bluetooth Headphone
More Ways To Play
The Bluetooth transmitter feature on H50 gives you more options for listening enjoyment.
Home Amplifier
*PCM format ONLY.
Amplifier For Turntable
H50 support both MC/MM, no worries about the compatibility.
2.1 System
Meet All Your Needs
Wireless Audio Amp
Spotify Amplifier
Play From Your Favorite Music
Multizone Amplifier
4stream app
4STREAM APP Does Everything
Amp with EQ
Make Your Personalized Music Style
Amplifier with Lan
Plug And Play
Amplifier with Display
OLED Display
Amplifier with Remote
remote
Multi-function Remote Control
4stream app
Plug And Play
OLED Display
remote
4STREAM APPAmp with EQAmplifier with LanAmplifier with DisplayAmplifier with Remote
Streaming Protocol
IEEE 802.11 b/g/n 2.4G/5G
Wired network
Speaker Power
2x50W @ 4ohm load at 24V
2x30W @ 8ohm load at 24V
Yes (WiFi)
Audio Channel
Stereo (L+R)
Stereo (L+R)
Music Service
Based on 62 reviews
77%
(48)
18%
(11)
3%
(2)
2%
(1)
C
Christopher Imbach
Really very solid tiny and clean receiver. Delighted!
I had an old pair of B&W DM602 S3 speakers knocking around and nothing to light them up. After poking around the internet for the cheapest way to give them Airplay, I settled on this little box.
I got the 32v version for no particular reason and, coupled with some acceptable Canare cables, now have really pleasant sound in my office… all burbling through the air courtesy of Apple Music.
With only 50 watts at 8 Ohm, you’re not going to shake any fillings loose, but the music gets plenty loud for a small room - and the quality of the sound stays solid all the way up. The amp doesn’t get too warm, even after hours of play. Between my computer and the phone app, everything that needs controlling is manageable. Software upgrades (2x in three days…) are handled via the app and are simple enough.
Fit and finish are very tidy and solid. The binding posts on the back are small, but seem willing to accept standard bananas. The crowns will fully unscrew and roll away, so pay attention when wiring. Also, flip the Ohm switch to your speakers liking. Easy to miss.
All told, this is a pleasure of an amp. My household audio is a few steps up in cost and listening pleasure with McIntosh gear driving Paradigm S8’s over rather more precious wires. AND that's exactly what makes this so special: for a tiny fraction of the cost, this little box has my office humming and is putting a smile on my face. That’s good value.
S
Stevan Dragic
H50
Just what I needed. A compact and feature rich amp. Only two downsides are that I would be a bit happier with at least 50W per channel, and Deezer is not working in network mode, so I have to use bluetooth.
C
Catalin Oprea
Excellent product. Very high quality.
Excellent product. Very high quality! Fast shipping, fast delivery.
J
Jesus de Luis
H50 rules
I was taking a look at Arylic A50 but I had some doubts, then I realized about the new H50 and... I felt in love
The Arylic H50 streaming amplifier offers an impressive blend of powerful audio performance and seamless connectivity.
With its robust design and high-quality components, the H50 delivers rich, immersive sound that enhances your audio experience.
Its user-friendly interface and compatibility with various streaming services make it a versatile choice for music enthusiasts.
Rigth now I am using and old speaker system till I can go to a new couple ones, but so impressive the audio I am getting
P
Paul Khoo
A good all-in-one just add speakers solution
I see this amp as great for individuals/families starting their first homes, an easy all-in-one just add speakers solution. It’s a good start for listening to music but a pity that there is no amplifier out as an upgrade path. When used in eARC mode, that's where the H50 performed really well. Normal TV viewing was great with voices locked on the center. Movie viewing was also good, though it can't compare to a proper AV amp. Thumbs up for TV/Movie, not so good for music. The amp sounds a bit "closed" with the soundstage falling just between the speakers. The depth of the soundstage was shallow and not high. Instrument placement was all right but the overall sound, sometimes typical of class D amps, was lean and sterile. Bass extension was not low enough while the treble was a bit light. It wasn’t a fatiguing listen but for serious listening, this won’t be my go to amp.
P
Piotr B.
Very usefull device:)
The Arylic H50 is a very useful and multifunctional amplifier with intuitive operation. It delivers excellent sound with clear details and powerful bass. Compact in size, it doesn’t take up much space and has a very stylish desing. It drives large floor-standing speakers with ease, and I highly recommend this device to demanding users.
