Up2Stream Mini - Multiroom Wi-Fi Streamer Board (No Amp)
Sale price$39.00
-WiFi, Airplay, Spotify Connect, Bluetooth 5.0, DLNA, UPnP wireless connectivity support.
Features
Wireless Connectivity
Up2stream Mini supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Lossless Audio
The Up2stream Mini is capable of supporting a wide range of lossless audio formats, such as FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Additionally, it can decode up to 192kHz/24bits and deliver CD quality audio output of 44.1kHz/16bits.
Music Services Support
Versatile Music Sources
The Up2stream Mini offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Mini makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Mini comes with a range of ready-to-use interfaces, including a 3.5mm line out, micro USB audio input, and a plug for SPDIF out, IIS out, Line Out, LED Indicator, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream Mini offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board, Up2stream ESS9023 DAC board, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Mini device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream Mini to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Mini. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream Mini offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
With the 4STREAM app, you can rename your Arylic streaming device's WiFi SSID and Bluetooth name. The changes will stay even after a factory reset, until you change it again.
Optional Remote Control
The optional remote control is a useful addition to the Up2stream Mini, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
*1. Warning: Up2Stream Mini must use 5V-1A DC input, higher voltage power
supply may damage the board.
*2. Up2stream Mini need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
Newest Firmware Version
Wireless Network
Power Input *①
5V-1A 2 pin connector
5V-1A micro USB input
Audio Input
Micro USB Input
Audio Output
Analog:
3.5mm Line Out (1 Vrms)
Digital:
I2S Out,
*②SPDIF Out (44.1KHz)
Not sure which one to choose? We selected all of our music streamer boards. Compare them and choose the best version for your needs.
① Up2stream Mini V3 need ACPWorkbench tuning tool to switch the SPDIF configuration from SPDIF out to SPDIF in.
Music Service
Power Input
5V/1A Micro USB
5V/1A Micro USB
5V/2A Type-C
Analog Audio Input
Aux In(3.5mm Jack & Pin)
Aux In (Pin)
Digital Audio Input
Spdif In (Pin)
Analog Audio Output
Aux Out (3.5mm Jack & Pin)
DAC: Integrated
DAC: Integrated
RCA (RCA & Pin)
DAC: ES9038Q2M
Digital Audio Output
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Opt & Coax)
Audio Format (Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
192khz/24bits (Hi-Res)
USB Playback
ACPWorkbench
Remote
Optional
Optional
Optional
Expansion Boards
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*②Spdif In Board
*②Spdif Out Board
*②Button Board
*②Volume Knob Board
*②IR Sensor Board
Display Panel
Suggestion
For single wireless projects
For Multiroom and Multi zone receiver Projects
Build Your Wireless Projects
wireless speaker
Wireless Speaker
Shared by Gary Ingram
diy suitcase speaker
Wireless Suitcase Speaker
Shared by Maarten Hekman
diy amplifier
Upgrade Your Amplifier
Shared by Simon Baynes
diy multiroom audio
DIY Multiroom Audio
Shared by Stefano
Compatible Accessories
Sale priceFrom $7.90
ESS9023 DAC boardbutton board
Sale priceFrom $10.00
ACPWorkbenchDSP tool
Based on 292 reviews
93%
(273)
6%
(17)
1%
(2)
L
Luca Tulipani
Almost perfect
It's a very valid product easy to setup and use. I already have 4 in my house. To be perfect I would love to see an official home assistant integration developed by arylic and also an landscape mode in the android app.
P
Peter Taylor
Simple device for a simple purpose
This up2stream mini was paired with a bookshelf setup that had an integrated amp. Coming from a dying original chromecast audio, switching to this was almost seamless. I was even able to recycle the old chromecast connectors.
If you use major streaming platforms for music like Spotify or Apple Music, you don’t even need to keep the 4share app on your device after setup. I am happy to have one less google thing and also one less app overall on my devices.
The connectivity is instant when going to use it. No lag, no having to redo connections like I was having to do with my chromecast. Bluetooth is there if you need it, but I specifically picked this because of the wifi - no messing with signal due to physical barriers.
The optional acrylic casing is worth it if you intend to have it freestanding and don’t want to mess with measuring and cutting your own.
It’s really cool to have a readymade device with optionality to be built into future applications if I wanted, while also being good at being a pre-amp receiver right out of the box, all for such a low cost.
A
Andrey Smirnov
Up2Stream mini and old radio of 1953
I purchased this card and connected the pickup to the 1953 retro radio without any problems. The sound is amplified through the original tube amplifier. Everything is fine, the sound is great. It is a pity that Russian radio stations are not working.
F
Frederik
Easy setup - haven't got any problems in almost 2 years
I have 2 up2stream mini-modules that I use daily to stream the radio or Spotify.
D
Denise Riediger
tutto ok da provare All ok works great advice seller
Mariusz Juraszek
Super AirPlay Empfänger für kompakte Lautsprecher
Als jemand, der in seinem Leben schon viele innovative Gadgets gesehen hat, war ich skeptisch, ob ein kleines Modul wie der Up2Stream Mini wirklich das Potenzial hat, ein herkömmliches Audiosystem in ein modernes Streaming-Wunder zu verwandeln. Doch als ich ihn in einem Lautsprecher zum Mitnehmen einbaute, änderte sich meine Meinung grundlegend. In meinem 60. Lebensjahr habe ich schon viele Entwicklungen erlebt – und dieser kleine Streaming-Kopf hat mich überrascht.
Erste Eindrücke und Vorbereitung:
Zu Beginn war klar, dass der Up2Stream Mini mit seinen kompakten Maßen von etwa 55 x 42 x 12 mm und einem Gewicht von lediglich 60 Gramm ideal in einen tragbaren Lautsprecher integriert werden konnte. Ich erinnere mich noch gut daran, wie ich das Modul in meiner Werkstatt auspackte und mir vorstellte, wie es in einem Gehäuse zum Einsatz kommen könnte, das ich überallhin mitnehmen kann. Mit der nötigen Sorgfalt und etwas handwerklichem Geschick baute ich den Mini in einen alten, aber geliebten Lautsprecher ein, den ich über die Jahre gesammelt hatte. Es war ein freudiger Moment, als ich die Vorbereitungen abschloss und wusste, dass sich etwas Großes ankündigte.
Integration in den tragbaren Lautsprecher:
Der Einbau verlief erstaunlich unkompliziert. Zunächst habe ich darauf geachtet, dass alle Verbindungen – sei es für die Stromversorgung oder den Audioausgang – sauber und stabil montiert sind. Ich entschied mich, einen separaten USB-Ladeadapter zu verwenden, um eventuelle Störgeräusche zu vermeiden. Die Montage im Gehäuse erforderte etwas Fingerspitzengefühl, da ich darauf achten musste, dass das Modul nicht nur mechanisch sicher fixiert, sondern auch gut belüftet ist. Schließlich sollte der Klang nicht durch Hitzestau beeinträchtigt werden.
Streaming und Bedienung:
Ein wesentlicher Pluspunkt des Geräts ist seine Unterstützung moderner Streaming-Dienste. Über die kostenlose 4STREAM-App – erhältlich für iOS und Android – konnte ich meinen Up2Stream Mini problemlos konfigurieren. Die Einrichtung verlief schnell: Ich verband das Gerät mit meinem Heimnetzwerk und richtete anschließend den sogenannten Direct Mode ein, der es mir erlaubt, auch unterwegs ohne eine vorhandene WLAN-Infrastruktur zu streamen. So kann ich nun, wenn ich an einem sonnigen Tag am See sitze oder im Park entspanne, meine Lieblingsmusik genießen, ohne auf Kabel oder stationäre Geräte angewiesen zu sein.
Die App bot mir nicht nur eine einfache Bedienung, sondern auch die Möglichkeit, Firmware-Updates durchzuführen, was für mich als Technikenthusiast immer ein wichtiges Kriterium ist. Ich schätzte besonders, dass ich zwischen verschiedenen Betriebsmodi wählen konnte: Ob im Standalone-Modus oder als Teil eines Multiroom-Systems – die Möglichkeiten schienen nahezu grenzenlos.
Persönliche Erfahrungen im mobilen Einsatz:
Das eigentliche Highlight war für mich die Anwendung im mobilen Lautsprecher. Früher war es stets mühsam, einen hochwertigen Sound unterwegs zu gewährleisten. Mit dem Up2Stream Mini konnte ich jedoch eine nahtlose Verbindung zu Musikdiensten wie Spotify und sogar zu meinem NAS herstellen, sodass ich jederzeit Zugriff auf meine gesamte Musiksammlung hatte. Besonders beeindruckend fand ich den Direct Mode: Ohne auf ein vorhandenes WLAN angewiesen zu sein, eröffnete sich mir eine völlig neue Flexibilität im Umgang mit Musik.
Der Klang, den ich aus dem modifizierten Lautsprecher hörte, war überraschend rein und detailreich – ein Beweis dafür, dass Technik nicht immer groß und sperrig sein muss, um beeindruckend zu sein. Selbst bei höheren Lautstärken blieb der Sound klar, ohne störende Verzerrungen oder Rauschen. Dies ist in meinen langjährigen Erfahrungen als Audioliebhaber selten geworden, denn oftmals muss man Abstriche bei der Klangqualität hinnehmen, wenn man auf Mobilität setzt.
Fazit und Ausblick:
Insgesamt hat mich der Up2Stream Mini in meiner täglichen Nutzung überzeugt. Die einfache Integration in meinen tragbaren Lautsprecher, gepaart mit der Flexibilität im Streaming und der herausragenden Klangqualität, macht dieses Gerät zu einem unverzichtbaren Begleiter für alle, die auch unterwegs nicht auf erstklassigen Sound verzichten möchten. Als jemand, der schon viele technische Entwicklungen miterlebt hat, kann ich mit ruhiger Zuversicht sagen, dass der Up2Stream Mini nicht nur ein kleines Gadget ist, sondern ein echter Game-Changer für mobile Audiosysteme darstellt.
Ich empfehle jedem, der auf der Suche nach einer innovativen Lösung für unterwegs ist, sich dieses Modul einmal genauer anzusehen. Mit dem Up2Stream Mini wird aus einem simplen Lautsprecher ein mobiles Kraftpaket – und das ist für einen erfahrenen Genießer wie mich ein echter Mehrwert im Alltag.
You May Also like
