Up2Cast Amp with Auracast Bluetooth Broadcasting Amplifier Board
- Build your own Auracast/LE Audio Bluetooth broadcasting amplifier or speaker.
- Maximum output of 50W x 2, with a jump switch to select L Mono, R Mono, or Stereo modes.
- Capable of broadcasting all inputs, including Bluetooth, Line In, Optical In, USB stick, and USB DAC.
- Compatible with other Auracast-enabled devices.
- Supports aptX, aptX HD, aptX LL, aptX AD, and LE Audio for superior sound quality.
The First
AURACAST Amplifier Board
New Audio Experience
Bluetooth Sync
Up2Cast AMP is a Bluetooth amplifier board that supports LE Audio and the Auracast broadcast function. It allows you to send audio from one master Auracast device to multiple slave Auracast devices simultaneously via Bluetooth.
As long as you remain within the Bluetooth broadcasting range, there is no limit to the number of slave Auracast devices you can broadcast to.
SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LE Audio
30M
Auracast
10M
12V – 24V
AUX in
USB Type-A port (for USB flash drive)
USB Type-C port (for PC connection)
Speaker out
Analog out (PH2.0-4P)
30Wx2@8Ω load at 24V THD+N<=10%
25Wx2@8Ω load at 24V THD+N<=1%
35Wx2@4Ω load at 18V THD+N<=10%
28Wx2@4Ω load at 18V THD+N<=1%
4Ω- 8Ω
20Hz – 20kHz
110*80*22mm
Add Up2Cast to each sound system or DIY audio project, and your system will become an Auracast-enabled device. It can then broadcast audio or receive broadcasts, allowing you to create a series of wirelessly grouped speakers.
You can Auracast any audio source supported by Up2Cast to another Up2Cast or Auracast-enabled device. For example, play music from your phone via Bluetooth and broadcast it to other Auracast-enabled devices.
You can broadcast to multiple Auracast-enabled devices simultaneously, such as Auracast speakers, earbuds, headphones, and hearing aids.
New Bluetooth Technology for Superior Sound Quality
LE Audio
Up2Cast AMP supports LE Audio, a new Bluetooth audio standard that offers multiple benefits, such as enhanced audio quality through the LC3 codec.
It delivers superior sound at lower bitrates compared to older codecs. Additionally, LE Audio supports multiple audio streams and improved device pairing, providing a more seamless experience across various Bluetooth devices.
aptX AD
Up2Cast AMP supports aptX, aptX HD, aptX LL, and aptX Adaptive, allowing you to build high-quality Bluetooth amplifiers or speakers for music or gaming.
Enjoy superior audio with your aptX-enabled devices.
More Efficient and Stable
Auracast offers a highly reliable connection, enhancing the experience with our audio products and minimizing interference in crowded wireless environments.
Group For More Power
Up2Cast Amp delivers 50W per channel when connected to a pair of stereo passive speakers. If you need more power for your sound system, you can activate the Mono L/R jumper and connect additional speakers, providing 100W per channel.
Total 100W
Total 200W
The free iOS & Android GO CONTROL app allows you to easily control both broadcasting and receiving broadcasted audio.
Quick get your favorite music style like pop, jazz, rock or customize yourself in the APP. You also can adjust crossover frequency and L/R balance in the APP.
GO CONTROL APP support browse and play the songs in your USB flash drive.
Tune Like Expert
Up2Cast supports the advanced ACPWorkbench tuning tool, allowing you to customize specific EQ settings for each channel.
What is the maximum number of devices I can broadcast to?
As long as the Auracast reciever in the Bluetooth broadcasting range, there is no limits.
What is the delay between the devices?
It is about 3-5ms between receivers.
It has received 2 reviews.
