S10+ WiFi Music Streamer
Updates Of S10+
New Design: The new design and material of the case improve the signal ratio.
Outlook: New OLED mode display and touch button with friendly use.
Spdif Out: New optical output for HQ audio transmit.
Type-C Port: New type-c port for 5V1A power supply and PC digital audio input.
S10+ WiFi Audio Streamer, User Manual, Remote, 5V1A Type-C Power Adapter and cable, Aux 3.5mm cable, 2-1 RCA Cable.
Easy To Get Started
Easy WiFi Pairing
USB Type-C
Line Out
Line In
USB
Play All In One System
Multiple Ways To Control
Personalize Your Music Style
Free EQ APP
Tune Like A Pro
5V/1A Type-C Input
Analog
Line In x 1 / 2 Vrms(3.5mm mini jack)
Digital
Type-C Input x 1
Analog
Line Out x 1 / 2 Vrms(3.5mm mini jack)
Digital
Optical Output x 1
Decoding
Up to 24bit/192kHz
Output
44.1kHz/16bit, CD quality
20Hz-20kHz
0.03%
91dB
105g
108 x 72 x 26.6mm
5V/1A Type-C
12V/1A DC Input
Aux In
Opt In
Aux Out
DAC: Integrated
DAC: ESS 9023
Opt Out
Opt Out
Coax Out
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
What is the DAC inside S10+?
The DAC of S10+ is integrated on the MCU.
Can S10+ work with other Arylic streaming products?
Yes, all Arylic streaming products are compatible with each other.
Does S10+ support DLNA & NAS?
Yes. You can find the music on DLNA and NAS in my music.
It has received 294 reviews.
