True Wireless Bluetooth 5.0 Game Earbuds M500
*Price calculated at checkout
In Stock & Ready To Ship:
Choose the plug type first
Description
True Wireless Bluetooth 5.0 Low Latency Game Earbuds With Mic and Large Battery Capacity
TWS BT5.0 Low Latency Game Earbuds
- Ultra-low latency game mode, lowest to 65ms.
- TW+ technology for better and stable connection.
- Music mode for high quality music playback.
- Bluetooth 5.0,connection range up to 15 meters.
- Touch button on both side for easy control.
- Take it out and use it right away(pair automatically).
- Audio quality optimized by DSP for music playback and call voice .
- Role switch, any one of the earbuds can work alone or together, no role of master or slave earbuds.
- 4-5 hours playback, 150 hours working with case battery, 3000mAh battery case
- Sport fit design and IPX5 waterproof.
- Voice assistant wake up.
- Earbuds battery indication on the phone.
M500 specifications:
- Bluetooth Version: 5.0
- Bluetooth wireless range: Up to 15m/ 50 ft
- Battery life: Earbuds 4-5 hours and 150 hours additional with charging case*
- Charge time: Up to 1 hour
- Drivers: 6mm
* May vary dependent on usage
Headphones
- Frequency response: 20 Hz -20kHz
- Impedance: 16士15% Ω
- Sensitivity: 100土3dB @ 1 kHz
- Max input power: 8mW
- Drivers: 6mm
- Approximate weight: 9.0 g/each
Microphone
- Frequency response: 300 Hz - 5 kHz
- Signal-to-noise ratio:> 55 dB
- Sensitivity (@1 kHz): -42土3 dB
- Pickup pattern: Omnidirectional
Touch controls
- MuicContols Play, pause, skip, previous
- Call Controls: Answer, reject switch, end
- General:Pair,power,activate smartphone virtual assistant
Battery
- Battery type: 2600mAh rechargable Li-PO battery Rated Capacity
- Charge time: Up to 1hour
*May vary dependent on usage
Range
- Bluetooth wireless range: Up to 15m/50 ft
Compatibility
- Devices with Bluetooth audio capability
- Supported codecs: SBC, AAC
It has received 11 reviews.
