S10+ WiFi Music Streamer
Entry-level
Sale price$69.00
- Stream music from your phone over WiFi, AirPlay, Spotify Connect, and Bluetooth 5.0.
- Rich Interfaces: Optical Out, Line In/Out, Type-C DAC input, Lan, USB Host.
- HD Sound: Support CD quality high-definition sound streaming.
- Support Spotify, Amazon Music, Tidal, Qobuz, TuneIn, Internet Radio and more.
- Multiroom: Sync music or play different songs across all rooms.
Bulk Discount
Version: S10+
✔Fast & Free Shipping
AirPlay Audio receiver
Versatile Wireless Connectitvity
Stream music over WiFi, Spotify Connect and Bluetooth 5.0
AirPlay
AirPlay
Play directly from your iPhone.
HD Music
HD Music
Enjoy high quality music.
Sync music or play different songs at the same time.
Music services
Rich Music Sources
Spotify, Tidal, Qobuz, TuneIn, Internet Radio, NAS and More.
optical Output
Transmit HQ sound to your system.
Lan
Plug And Play
Quick Start with Lan cable connected. There is no WiFi pairing process.
EQ
EQ
Personalize your music style.
Easy To Get Started
WiFi audio streamer
Easy WiFi Pairing
network streamer
music services
streaming your sound system
USB Type-C
Line Out
Line In
USB
Play All In One System
multiroom audio
Sync Music Across Rooms
multiroom system
Play Different Audio Sources At The Same Time
multiroom group
Multizone Group
multiroom control
Easy And Full Multiroom Control
Multizone Group
multiroom audiomultiroom systemmultiroom groupmultiroom control
Multiple Ways To Control
Personalize Your Music Style
GO CONTROL APP
Free EQ APP
ACPWorkbench tuning tool
Tune Like A Pro
Newest Firmware Version
Wifi
Ethernet
Streaming Protocols
Power Input
5V/1A Type-C
12V/1A DC Input
Music Services
Analog Audio Input
Aux In
Digital Audio Input
Opt In
Analog Audio Output
Aux Out
DAC: Integrated
DAC: ESS 9023
Digital Audio Output
Opt Out
Opt Out
Coax Out
Sample Rate
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
USB Playback
ACPWorkbench
Display
Remote
Based on 288 reviews
81%
(233)
17%
(49)
1%
(4)
1%
(2)
T
Trent Stephens
The best part of my stereo system
I love my 80s hifi stereo system and for years have been looking for a way to preserve the sound quality with digital audio. This device not only does that better than any competitor but it also allows me to take my stereo sound and share to speakers around the house. This truly is my favorite new part of my smart house. I know I'm going to buy a lot more of them eventually.
S
Sandro Arrigoni
Incredible little device
I ordered my S10+ because I wanted a solution that would let me play my music over bluetooth, airplay and could stream Spotify directly.
Thanks to the S10+ I was able to comfortably and easily set this up. Build quality is about as expected. Shipping was quick. For anyone looking for a multiroom setup on a budget, this is a great option.
For the geeks, there is also a quite self explanatory API to play around with.
t
tonio
This streamer does what is expected of him
This entry-level streamer allowed me to recycle a Stereo Box DS amp and a Bose Acoustimas system.
Great product to associate with the ACPWorkBench software (be careful the license is attached to a Windows installation, if you reinstall Windows on the same machine, you lose the license, it's not cool)
G
Giorgos Kapetanakis
J
Jacques Lambert
Great Gadget
It performs exactly as advertise, easy to install.
D
Donald V
Works but requires very strong WiFi
I have not been able to make the device work for me. When I set it up while it is right next to the router, it works well (Apple Play). When I move it to the location where I actually need it, next to the sound system, it will stream for only a minute or two before dropping out. (Other devices seem to work fine with the WiFi in that location) I have tried changing to another WiFi network from an extender that I have that has a stronger signal in that area, but the device insists on connecting only to the original WiFi network even after factory reset. So I am frustrated by the setup.
