Up2Stream Pro - Multiroom Wireless Receiver Board (No Amp)
-RJ45 wired network and WiFi, Airplay, Spotify Connect, Bluetooth 5.0, DLNA, UPnP wireless connectivity support.
Up2stream Pro
Up2Stream Pro is a versatile audio receiver board that supports both WiFi and Bluetooth connectivity, making it easy to add network and streaming capabilities to your existing audio equipment. With the 4STREAM app, you can stream music from a variety of sources including your phone, cloud, NAS, and popular streaming services like Spotify, Apple Music, Amazon Music, Tidal, Deezer and Qobuz.
It also supports multiroom and multizone control, allowing you to play music in different rooms or areas simultaneously. Whether you want to create your own audio source receiver, wireless audio amplifier, wireless speaker, wireless speaker furniture, or a multiroom audio system, Up2Stream Pro provides a convenient and flexible solution.
Features
Wireless Connectivity
Up2stream Pro supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream Pro features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Lossless Audio
The Up2stream Pro is capable of supporting a wide range of lossless audio formats, such as FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Additionally, it can decode up to 192kHz/24bits and deliver CD quality audio output of 44.1kHz/16bits.
Music Services Support
Versatile Music Sources
The Up2stream Pro offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, USB, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Pro makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Pro comes with a range of ready-to-use interfaces, including a 3.5mm line out, 3.5mm line in, micro USB audio input, and a plug for SPDIF out, IIS out, Line in, Line out, LED indicator, IR extension, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream Pro offers several optional expansion boards and DIY Bluetooth speaker kit that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board, Up2stream ESS9023 DAC board, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Pro device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream Pro to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Pro. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream Pro offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
With the 4STREAM app, you can rename your Arylic streaming device's WiFi SSID and Bluetooth name. The changes will stay even after a factory reset, untill you change it again.
Optional Remote Control
the optional remote control is a useful addition to the Up2stream Pro, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
*1. Warning: Up2Stream Pro must use 5V-1A DC input, higher voltage power
supply may damage the board.
*2. Up2stream Pro need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
5V-1A 2 pin connector
5V-1A Micro USB input
Analog:
3.5mm Line Input (1 Vrms)
Digital:
Micro USB Input
Analog:
3.5mm Line Out (1 Vrms)
Digital:
I2S Out,
*②SPDIF Out (44.1KHz)
20Hz to 20kHz
91dB/0.03% @ 0dBFS, 1KHz
Support NAS with DLNA support
87.6*49.6*15mm
200g
220mm Internal WiFi Antenna
4Pin 220mm PH2.0 Cable
7Pin 220mm PH2.0 Cable
2Pin 220mm Power Cable
User Manual
Device on:
Long press once: Switch off
Device off:
Short press: Switch on
⚪White-WiFi & network mode:
Solid- WiFi is connected
🔵Blue-Bluetooth mode:
Solid- Bluetooth is connected
🟢Green-Line in mode
🔴Red-USB mode
🟡Yellow-connect to PC
① Up2stream Mini & Up2stream Pro need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
5V/1A Micro USB
5V/1A Micro USB
5V/2A Type-C
Aux In(3.5mm Jack & Pin)
Aux In (Pin)
Spdif In (Pin)
Aux Out (3.5mm Jack & Pin)
DAC: Integrated
DAC: Integrated
RCA (RCA & Pin)
DAC: ES9038Q2M
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Opt & Coax)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
192khz/24bits (Hi-Res)
Optional
Optional
Optional
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*②Spdif In Board
*②Spdif Out Board
*②Button Board
*②Volume Knob Board
*②IR Sensor Board
Display Panel
For single wireless projects、DIY Bluetooth speaker、 DIY WiFi speaker.
For Multiroom and Multi zone receiver Projects
Build Your Wireless Projects
Wireless Speaker
Shared by Orazio Laudi
Repair Your Audio Gear
Shared by Timo
Build Your Own Wireless Speaker
Shared by Чуб Александр Андреевич
Upgrade Your audio equipment.
Shared by Jarek
Can Up2stream Pro connect to my own DAC?
Yes, just connect the correspond pins to your DAC
You need to connect IIS_DATA/LRCK/BCLK/MCLK/VCC_3V3(5V)/GND
Is there a connection for triggering a relay to switch on/off an external amplifier?
Yes. but need to use our dsp tool ACPWorkbench to define the GPIO to work as relay.
Can I stream from YouTube ?
Yes you can stream YouTube by Airplay or Bluetooth.
Currently , Up2stream Pro only support connecting google home or Alexa via Bluetooth or line in.
It has received 198 reviews.
